308 headrest removal | FerrariChat
Discussion in '308/328' started by jon s, Apr 6, 2009.
  1. jon s
    jon s Formula Junior
    Mar 9, 2005
    509
    pocasset ma
    jon shoukimas MD
    its time to put the new leather covers on and after doing the forum literature search it seemed like the job is a super pain in the ass. the drawing in the parts catalog isn't much help. here's what i did. the seats had been recovered so the back cover rivets had been replaced with screws. removal of the cover was the easy part. the legs of the headrests run in vertical tubes welded to the thick cross bar. if you remove the hogs holding the leather to the small cross bar just below the large one and also the first two hogs on the sides of the leather you have enough stretch to run your finger up along the vertical tube (you split the foam backing) until you find the linch pins that act as the spring detent and stop for the rods. with the seat all the way forward in the runners and tilted forward there is more than enough room to work. the pins are about a thumbs length up from the cross bar (go further if you are small) and are removeable with needle nose pliers. you can feel them easily and after you split the foam they're easy to see. i saw a picture in one of the ealier forums with the leather rolled all the way up but i don't see how to do that without damage to the leather and the above method worked fine.
    birdman mentioned that he had some oem plastic caps for the top of the seat; are you interested in making some? regards, jon s
    john a barnes likes this.
  2. mwr4440
    57,919
    Bavaria, The 'Other' Germany
    Mark W.R.
    Jon,
    Sorry. I have no idea what you are talking about.
    However, on my 308 there are detents, down a few inches from the top of the seatback. Feel around (you gotta push) and you should find them. Push in and have someone else pull and remove the head rest. It is a SERIOUS PITA but do-able.
    Mark
    Rosey likes this.
  3. AHudson
    AHudson F1 Rookie
    2,781
    Florida
    Adams Hudson
    I'm in the process of removing my 328 headreasts now, and am having a difficult time. I presume the method is the same, but I must admit, I'm a little confused too. Any pictures would be supremely helpful. Very timely thread!
  4. jon s
    Mar 9, 2005
    509
    pocasset ma
    jon shoukimas MD
    mark: i suspect there may be differences from year to year after reading the prior posts. all i can tell you is that after i removed the linch pins the headrests came right out. my 308 is an 81.
    jon s
  5. AHudson
    AHudson F1 Rookie
    2,781
    Florida
    Adams Hudson
    #5 AHudson, Apr 7, 2009
  6. jon s
    Mar 9, 2005
    509
    pocasset ma
    jon shoukimas MD
    those are the very pins. i did the second seat today; removed the pins and had it back together in less than 30 minutes. cut the hog rings with a good wire cutter - much faster than using pliers and you won't damage the leather. slit the foam up the post until you see the pin - grab the long end and pull backwards - they pull right through the foam. finally no more hog rings - i reattached the leather with 50# black plastic wire ties - quick and easy. i'll leave the pins out until i recover the seats (if ever). i don't see how you could easily get them back on without taking the seat apart. good luck. jon s
  7. mwr4440
    57,919
    Mark W.R.
    Jon,
    You must be right but the varience may even be greater than we think. Mine is a 1981 also, North American version.
    About 3-4 inches from the top of the seat, behind the leather of the seat back, there are two detents you push in and when depressed, down go or out come, the head rests.
    Things that make you say Hmmmmmmmmmmmmmmmmmm.
    Mark
  8. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,804
    Cerritos, CA.
    On that pic, it looks like the notches on the post are cut too deep, I think this is why it's so hard to adjust.
  9. Sparky328
    Sparky328 Rookie
    May 29, 2017
    1
    Long Beach, New York
    Robert Savio
    How do I just adjust them not take them out
  10. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    My 82 308gtsi headrest height adjustment is pulling them up and pushing them down.
  11. miketuason
    Feb 24, 2006
    15,804
    Cerritos, CA.
    Mark just explained it on post #7
  12. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,803
    Australia
    Mark R
    If you have never adjusted your headrests in over 25 years you may need to spray a very small amount of SILICONE spray (NOT WD40) down between the chrome struts and the black plastic surrounds. Then wiggle and push the headrests up and down a little for the spray to penetrate.
    You should be able to lift the headrests up with a bit of effort- you will definitely need to use a fair bit of force. If you have a GTS it's a lot easier to take off the targa roof to get better access to pull the headrests straight up from the top.
  13. Ptama10
    Ptama10 Rookie
    Jun 12, 2018
    40
    Peter
    27811 likes this.
  14. jmaienza
    jmaienza Formula Junior
    Jan 8, 2009
    628
    Massachusetts
    Joe
    Removal of the headrest has become one of the "How To Do It" topics that drives me crazy. There are usually several ways to accomplish a task and everyone can choose their method. However, some common sense and a bit of thinking should be the first step in the process before ripping half of your seat apart.
    Our Ferraris are unique in many ways when it comes to adjustments and maintenance, but moving a headrest up and down is not one of them! Do you really think the seat designers made the seat only to have the customer remove the seat, drill out rivets, blindly cut foam, remove clips and then put everyone back together and re-install the seat. What happens if you raise the headrest, re-install the seat and then decide you don't like the new position? Are you supposed to do it all again?(This is where the thinking and common sense comes in)
    The headrest will come out once you push in the clips at the right spot with your fingers. No seat removal, no drilling, no cutting and no silly business is involved.
    https://www.ferrarichat.com/forum/threads/headrest-question.356323/#post-141221764
    (detailed directions on post #13)
  15. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,803
    Australia
    Mark R
    Great advice, I used that technique to lift my headrests that had been in the lowest position for 20 years.
    All i'd say is use silicone spray instead of WD40 as it can stain the leather if you use too much and it also smells terrible.
