2013 California Tachometer & gauge cluster | FerrariChat
Discussion in 'Technical Q&A' started by Reficul, May 28, 2021.
  1. Reficul
    Reficul Rookie
    May 28, 2021
    11
    Queen Creek, AZ
    Claude
    I just bought this car, Excited Ferrari newbie.
    Driving it back, stopped for a night, next morning started car and gauge cluster was all dead: tachomter speedometer, information cluster, and what looks like the trunk open light is on.
    car operates normally, is this possibly a fuse, or something more sinister?
    -any help or advice appreciated..
  2. Qavion
    Qavion F1 World Champ
    14,237
    Ian Riddell
    #2 Qavion, May 28, 2021
    On some cars, the F1 gearbox light looks a lot like a trunk open light.
    If you've lost your instrumentation, it may be affecting the F1 gearbox. The instrument cluster typically provides the F1 system with speed data.
    A blown fuse is something sinister. It's just cheaper as a temporary fix ;)
    Anyway, check your handbook for fuse locations. There may be more than one for the instruments (battery ("+30") and ignition key ("+15") instrument power fuses).
    (EDIT: although the graphic says the buzzer will sound for an F1 gearbox problem, if your instrument cluster is dead, the buzzer in the instrument cluster may also be dead)
  3. Qavion
    14,237
    Ian Riddell
  4. Reficul
    Reficul Rookie
    May 28, 2021
    11
    Queen Creek, AZ
    Claude
    Thank you very much, Quavion.
    Qavion likes this.
  5. Reficul
    Reficul Rookie
    May 28, 2021
    11
    Queen Creek, AZ
    Claude
    As a follow up, i shipped the car back and i'm flying out to San Diego tomorrow to pick up a newer one.... this one a single owner 2017 California T... pretty excited
    Qavion likes this.
  6. mstBfast
    mstBfast Rookie
    Jul 5, 2022
    4
    Las Vegas
    Dennis Grady
    same issue picked car up last night (2010 California) Tach Black as night. Any new insights on cause and cure?
  7. Qavion
    14,237
    Ian Riddell
    Just the tacho, no other instruments or displays? Is the tacho needle moving?
    Are you talking about the instrument lighting which comes on with your sidelights/headlights, or something else?
  8. mstBfast
    mstBfast Rookie
    Jul 5, 2022
    4
    Las Vegas
    Dennis Grady
    Tach is functional, horse lights, limiter lines light, numbers are dark, Gear indicator displays fine.
  9. Qavion
    14,237
    Ian Riddell
    So most likely an instrument cluster problem rather than an external power supply issue. There are quite a few confusing posts on yellow tach illumination on the Cali subforum:
    https://www.ferrarichat.com/forum/posts/148589097/
    https://www.ferrarichat.com/forum/threads/2010-california-yellow-tach-not-backlit.615571/#post-147796630
    Experts?
    Instructions on how to remove the cluster here:
    https://www.ferrarichat.com/forum/threads/how-do-i-remove-instrument-cluster-cali-t.623508/
    If DIY repairs fail, send it away to someone like this:
    https://www.facebook.com/totaltronics/videos/ferrari-california-instrument-cluster-bench-test-after-repair/531289470863298/
  10. mstBfast
    mstBfast Rookie
    Jul 5, 2022
    4
    Las Vegas
    Dennis Grady
    Well if a picture is with a 1,000 words then the numbers should light. The second thread showing the bench test everything lights.
    Thanks for the reply!
  11. Qavion
    14,237
    Ian Riddell
    The numbers appear to light up very dimly in the first part of the video (more noticeable for the red/orange numbers). I don't know if there is a second brightness level when the external lights are turned on. Towards the end of the video, the studio lights are turned off and the instrument brightness increases dramatically, but I don't know if the camera just adjusted the light levels.
    Some folks were complaining that the yellow background makes the numbers hard to see in daylight.
    It's probably best to ask what is normal on the Califoria sub-forum.
  12. windsock
    windsock Formula 3
    1,149
    yellow tachometer has a different backlight strategy then the red and black. We had a a lot of complaints when the cars first came out.
    Backlighting is not controlled by the headlamp switch but by the twilight sensor. The backlighting comes on much earlier on the red and black tachometers then it does on the yellow. Many people complained the yellow tach was hard to see especially in bright sun due to the shadow created by the binnacle
    mstBfast and Qavion like this.
