308 crank sensor | FerrariChat
308 crank sensor
Discussion in '308/328' started by Tonksy1, Apr 5, 2019.
  1. Tonksy1
    Tonksy1 Karting
    Jun 21, 2016
    91
    New Zealand
    #1 Tonksy1, Apr 5, 2019
    Hello Ferrari chatters.
    I am currently trying to solve a problem with miss in the engine( 83 308 QV). After replacing leads, extenders and rotors, I'm now looking at replacing the crank sensors.
    My query is that when looking on superformance website for a couple of new ones, it states that the sensor they sell is for engines after #864. My engine number is #0670. Do I require some other kind of sensor?I thought there was only one type. Also can someone confirm all three sensors used are identical.
    Thanks in advance
    Dean (NZ)
  2. rjlloyd
    rjlloyd Formula Junior
    Jun 19, 2014
    447
    Brisbane, Australia
    Richard Lloyd
    Hi Dean , all 3 sensors are the same. I bought 3 for my 81 2VI . The only thing I had to change was the plug on the end of the cables.
    waymar likes this.
  3. Tonksy1
    Tonksy1 Karting
    Jun 21, 2016
    91
    New Zealand
    Thanks Richard.
    Have you heard of their being 2 types of sensors? I'm still a bit confused on why they list a crank sensor on superformance website for engines after #864
  4. rjlloyd
    Jun 19, 2014
    447
    Brisbane, Australia
    Richard Lloyd
    It’s my understanding that the earlier type of sensor are NLA and the later type as pictured were used by the factory from that engine number. If fitting them to an earlier engine you’ll need to modify the sensor to suit
  5. Tonksy1
    Tonksy1 Karting
    Jun 21, 2016
    91
    New Zealand
    That makes sense. Thanks Richard
  6. Steve Magnusson
    26,747
  7. Tonksy1
    Tonksy1 Karting
    Jun 21, 2016
    91
    New Zealand
    Yes that's the connector I have. Shouldn't be a problem to sort a new one.
    Thanks Steve.
  8. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,214
    CT
    John Kreskovsky
    FrannyB, Tonksy1 and thorn like this.
  9. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,145
    SanFrancisco BayArea
    1983 US 308 GTS QV
    I successfully replaced one of my crank sensors with the one from Superformance. My QV has a lower engine number than yours. The holes for the mounting studs were too far apart and I had to elongate them into slots to make the sensor fit. The studs do not centralize the sensor (its plastic body does that) so the sensor works just fine.
    Regarding the misfire, also check grounds such as to the coils. If the misfire is on one bank only try swaping sparkboxes.
  10. Tonksy1
    Tonksy1 Karting
    Jun 21, 2016
    91
    New Zealand
    Thanks Brian. Good to know.
  11. Bobbytinvab
    Bobbytinvab Karting
    Jan 22, 2010
    237
    Virginia Beach, VA
    Bob T
    Those "crank sensors" were also used by Ford Cosworths. I googled the part number that was on the side of the sensor, and was able to purchase three for the same price as one that comes in the "Horsey" box. Unfortunately I cannot remember the part number, but I'm pretty sure it was on the part itself. It was a Magnetti Marelli part. I did have to elongate the mounting holes just a bit, but they worked fine. I also regrounded all my connections as Brian indicated ... that was almost ten years ago, and still going strong ... Best of luck.
    Tonksy1 likes this.
  12. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    I used one of the new ones on my ‘80. Worked fine but had to use a trailer light connector in the end and like others said make the holes a tiny bit bigger.
    Tonksy1 likes this.
  13. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    I think there are many vehicles that use these sensors. It's been a while since I purchased one. I think it was from a Volkswagen..Much cheaper than the F part.
    Tonksy1 likes this.
  14. Baltz1969
    Baltz1969 Karting
    Apr 24, 2017
    74
    Chula Vista, CA
    Jose Baltz
    Besides cleaning the coil ground points, also clean the ground points for the the Control Modules
    Tonksy1 likes this.
