355 alarm is driving me nuts! Please help! | FerrariChat
Discussion in '348/355' started by SA Mike, Dec 1, 2019.
  1. SA Mike
    SA Mike Karting
    May 25, 2019
    52
    Texas
    Michael Martinez
    So for the last couple of months the alarm has been going off for no reason. And I don’t know how it’s supposed to sound but it’s just a loud constant piercing beeping noise. Doors, rear hatch, hood shut. So I figure today is the day I go out the garage and try to find out what the issue is. I have had the battery on a trickle charge with the battery on the off position. For a week or two. So I unplug the charger and as soon as I turn the battery to the on position the alarm/beeping goes off. I try to shut if off the the fob and no luck it will not stop. I get in the car and see if starting the car will stop the alarm and the car starts right up with the alarm/beeping still blaring as loud as can be. The car is running and the alarm is still on? So what can it be.
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,524
    San Carlos, CA
    Mitchell Le
    Just cut the wires to the alarm speaker and silence the useless piece of ****.
  3. SA Mike
    SA Mike Karting
    May 25, 2019
    52
    Texas
    Michael Martinez
    Lol. What about pulling the fuse. I would hate cut wires. Also would doing that prevent the car from starting.
  4. yelcab
    Nov 29, 2001
    13,524
    San Carlos, CA
    Mitchell Le
    Your car is running just fine while the alarm is blaring, why would that be different. The alarm horn is accessed with the front bumper removed so that is where you start.
  5. SA Mike
    SA Mike Karting
    May 25, 2019
    52
    Texas
    Michael Martinez
    Well removing the bumper is a little beyond my skill set. Any other way?
  6. Badabing!
    Badabing! Formula Junior
    Mar 30, 2014
    731
    NYC
    Hold the button on the key fob down for a few seconds. That's how you reset/shut off a tripped alarm.
  7. Qavion
    Qavion F1 World Champ
    14,240
    Ian Riddell
    #7 Qavion, Dec 1, 2019
    You shouldn't need to remove the bumper. Just remove one of the panels under the front bumper. Figuring out which one is the hard part. It's on the left hand side on my RHD car.
    The siren is possibly faulty. When you arm/disarm the alarm, the immobiliser ECU sends a signal to the alarm and the memory circuits inside remember this (even with the car's battery off). Refer to other message threads on battery/siren replacement. You may find the siren's battery leaking onto the siren circuits.
    WATSON likes this.
  8. SA Mike
    SA Mike Karting
    May 25, 2019
    52
    Texas
    Michael Martinez
    I did I held it down for five seconds or more. Still didn’t shut off.
  9. SA Mike
    SA Mike Karting
    May 25, 2019
    52
    Texas
    Michael Martinez
    Ok I’ll try that but like I mentioned before the sound is a piercing beeping noise is this the same thing. It’s not really a siren noise. Thanks for the reply.
  10. Qavion
    14,240
    Ian Riddell
    Where is the noise coming from? The front of the car? Inside the cabin?
  11. SA Mike
    SA Mike Karting
    May 25, 2019
    52
    Texas
    Michael Martinez
    It’s coming from the front of the car. Looked at some other threads, so maybe the siren battery? I have noticed (before all this happened) that the alarm light on the dash was on when I was driving the car. So I guess my question now is how to get to the siren to replace the battery or the unit itself.
  12. Qavion
    14,240
    Ian Riddell
    According to the wiring diagrams, the immobiliser also triggers the car's horn. Could it be that the horn is normally so loud, the siren's odd noise isn't readily noticeable to owners?
  13. WATSON
    23,679
    WI
    The red dash vent light on while driving means the siren battery is dead.
    I replaced mine awhile ago.
    I don't recall how I did it, but it did not require the front bumper to come off.
  14. SA Mike
    SA Mike Karting
    May 25, 2019
    52
    Texas
    Michael Martinez
    Do you know what side it’s on or where it’s located.
  15. WATSON
    23,679
    WI
    #15 WATSON, Dec 1, 2019
    It's been three years now.... EDIT: I did this in 2012. Man time flies!
    Drivers side. Pretty sure I went in by jacking up the car and pulling the access panel that is forward of the front wheel.
    I replaced it with a Corvette alarm that was a drop in replacement with a small harness.
    Alarm was a Bosch 15213135
    Tucked some acoustic fabric in the output portion of the horn to lower the volume (ie: stuffed a rag in the damn thing to shut it up)
    Qavion likes this.
  16. phrogs
    phrogs F1 Veteran
    7,341
    Kzoo Michigan
    Alarm on my 98 GTS F1 is on the Left hand side.
    remove the small faring onnthat side of the bottom of the bumper gains you access but Id remove the front wheel and then the wheel well, I think its easier to reach like that.
    WATSON likes this.
  17. SA Mike
    SA Mike Karting
    May 25, 2019
    52
    Texas
    Michael Martinez
  18. SA Mike
    SA Mike Karting
    May 25, 2019
    52
    Texas
    Michael Martinez
    Thanks for all the replies! Gonna pull the siren and see if it’s just the battery or the unit.
    Thank you sir!
  19. SA Mike
    SA Mike Karting
    May 25, 2019
    52
    Texas
    Michael Martinez
    thanks Watson!
  20. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    Qavion likes this.
  21. Qavion
    14,240
    Ian Riddell
    If it is just the battery, I'm wondering how it stops the siren disarming. If siren battery power isn't available, you'd assume the main battery would take over and power all the internal circuits. I think it's more than just a battery problem, but some other damage has occurred because of battery leakage. Expect some damage as in that link that emac provided.
  22. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    You are probably right Qavion. I am sorry, I didnt mean to suggest that the battery was the cause of the OP issues. I got a bit side tracked. Hopefully, SA Mike can get the siren removed and opened up then post what he finds.
  23. 308 GTB
    308 GTB F1 World Champ
    11,713
    New Jersey
    Barry Wolinsky
    Michael, there's no need to cut off the battery when you have your car hooked up to a trickle charger. Also, the alarm siren battery depends upon current from the battery to keep its battery charged. You might be able to bring your siren module back to to proper functioning order by driving your car around for a while. Use the trickle charger when your car is parked in your but don't cut off the battery.
    Barry
    Qavion likes this.
  24. Qavion
    14,240
    Ian Riddell
    Good point. In fact, if you attach the trickle charger to the engine bay battery bus bar (and nearest chassis earth) or the cigarette lighter and disable the battery using the cutoff switch, the car's battery won't charge. Both the postive and negative charger leads must be in some way attached to the positive and negative battery terminals. The battery negative is hooked up to the chassis via the battery cutoff switch.
    To recharge the siren battery it must either be attached to the battery's (positive and negative) or the trickle charger's (positive and negative). The trickle charger positive will always be attached to the siren battery positive (wherever you attach it... battery, cigarette lighter*, engine bay bus bar, etc). It's the siren battery's negative (earth) which is the tricky part. The siren battery's negative lead is attached to a particular wiring splice which is attached to chassis earth in a very roundabout way.
    *unless your cigarette lighter only works with the ignition on.
    308 GTB likes this.
  25. Mike Morrissey
    Mike Morrissey Formula 3
    1,142
    Denver, Colorado
    Mike Morrissey
    I found it necessary to replace my siren battery a few months ago. The siren is located on a left hand drive car, just ahead of the front left side marker light. As mentioned earlier, simply remove the bottom left access panel under the bumper. For better access, remove the left wheel and the panel ahead of the wheel. The siren is held to its bracket with two hex nuts. They simply need to be loosened, not removed, as they are captive; the siren will slide free of the bracket with enough wire harness length to drop from the vehicle to disconnect the connector.
    Early Bosch sirens have four plugged screws that need to be removed to separate the housing for circuit board access. Later models will need to be cut open along the seam as was the case with mine. My batteries measured correct voltage, however there was not enough current capacity for the circuit to operate properly, thus my center air vent LED was luminated during drive. I replaced my batteries with a 9v NiMH battery (7.9v under load) which fit inside the siren housing.
    Qavion likes this.
