355 - 355 for auction on the drivenexchange | FerrariChat
355 355 for auction on the drivenexchange
Discussion in '348/355' started by Natkingcolebasket69, Jul 27, 2020.
  1. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    Jackie and bill and sgtpeper like this.
  2. krazykarguy
    krazykarguy Formula Junior
    Apr 17, 2014
    732
    Fort Mill, SC
    Matt
    Seller claims tires are recent, but the date codes show otherwise (7 year old tires).
    This causes a bit of doubt on the rest of the ad, although I believe it to be an original 6-speed car.
    Natkingcolebasket69 likes this.
  3. Natkingcolebasket69
    Haven’t heard of many converted 355’s. I’m sure there are plenty. How could one verify?
  4. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I think it is in the VIN or maybe that is just spider designation not GB type?
  5. Natkingcolebasket69
    Looks clean though! I got too much time on
    My hands with this covid 19!
  6. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,628
    Elliott Caras
    Wonder why the seat belt receptacles have been changed to non original.
  7. Natkingcolebasket69
    I had not noticed that!
  8. phrogs
    phrogs F1 Veteran
    7,341
    Kzoo Michigan
    Probably wanted to fix the pink sun faded ones thing is many suffer from that.
  9. krazykarguy
    Apr 17, 2014
    732
    Fort Mill, SC
    Matt
    I think all Spiders (regardless of transmission type) carry a ‘48’ VIN code on the tag. It’s the same with our ‘97.
    technically, there is no difference in the equipped transmission (i.e. manual vs. automatic) - only the way it functions. So I don’t think that the VIN can tell this.
    phrogs likes this.
  10. Natkingcolebasket69
    If the car goes for 55k I think it’s a good deal!
  11. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,628
    Elliott Caras
    Easy fix with some TLC. Can rejuvenate the plastic.
  12. phrogs
    phrogs F1 Veteran
    7,341
    Kzoo Michigan
    #12 phrogs, Jul 27, 2020
    Yes There's nothing in the vin stating the transmission type.
    It would be a lot of work to totally change a F1 to appear as a stick car. Nothing to do with the shifting stuff that's not a big deal but there's plenty of other items that some would over look.
    I mean the dash badge is nothing but my car says 355F1 it's not a simple swap that would take effort.
    plus the electrics for the F1 I'm not sure if it's a stand alone harness or if it's integrated into the dash and body harnesses, but there's certain things swaped for the gear indicator not sure if the harness has the plug for the other gauge oil pressure or temp?? I can't recall stuff like that would take effort to change.
    did you take it all apart? and I'm thinking interior spray dye?
  13. PaulK
    PaulK F1 Rookie
    4,780
    Michigan
    Paul
    You should be able to run the VIN at a dealer and have them check the build.
  14. bjwhite
    bjwhite F1 Rookie
    4,805
    Seattle, WA
    Brian White
    Care to start a new thread sharing your process?
  15. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,628
    Elliott Caras
