355 soft top correct fluid | FerrariChat
Discussion in '348/355' started by LmnsBlu355, Mar 7, 2010.
  1. LmnsBlu355
    LmnsBlu355 Formula Junior
    Dec 28, 2009
    284
    NY
    Jordan S.
    I need to add fluid to my 355 soft top reservoir. I've done a search and info here is not 100% clear.
    I have a liter of Pentosin CHF 202 which is a synthetic. It says it is compatible with Pentosin CHF 11 (Both are synthetic). It is NOT compatible with Pentosin CHF 7.1 which is mineral based.
    I've seen on this forum rec's to use ordinary hydraulic jack oil (which I assume is mineral based) and rec's to use "Pentosin" but no info on exactly which formula.
    Does anyone know the correct specs for the fluid to add to original? I don't want to mix incompatible fluids.
  2. FerrariDeeJay
    FerrariDeeJay Formula Junior
    Jun 2, 2009
    418
    Chino, CA
    Michael
  3. rizzo308
    rizzo308 F1 Rookie
    2,775
    Perth, Australia
    riggio
    i used hyd/oil from mercedies dealer
  4. f355jimv
    f355jimv Formula Junior
    Jan 21, 2008
    685
    Southern California
    Jim
    Purchased the oil from the local Mercedes Benz dealer.
    Works fine.
  5. mike_747
    mike_747 Formula Junior
    Dec 15, 2008
    794
    Seattle
    Ditto and my Ferrari tech. ok'd this fluid as well (*Benz fluid ~ $20/qt)
  6. f355spider
    f355spider F1 World Champ
    18,043
  7. LmnsBlu355
    Dec 28, 2009
    284
    NY
    Jordan S.
    Thanks for the info. I've been obsessing over this for the past 24 hrs. A very informative older thread:
    http://www.ferrarichat.com/forum/showthread.php?t=31532
    In summary:
    Ferrari Original Fluid: Esso UNIVIS J26 hydraulic oil
    Recommended alternative: Mercedes ZH-M (a.k.a Aral Vitamol ZH-M)
    I'll be stopping by the MB dealer in the a.m.
    I still don't know if all this really matters but would feel really silly if I added Pentosin CHF 202 or AW32 generic hydraulic fluid (both here in my garage) and developed a leak or ruined a hyd. ram.
    Thanks again.
