360 Open Light Surgery | Page 2 | FerrariChat
Discussion in '360/430' started by Scott SMC, Aug 8, 2012.
  1. tr328
    tr328 Formula Junior
    Jun 19, 2003
    905
    Pacifica, California
    Darryl
    Yes, please post pics of magnet system setup.
  2. tr328
    Jun 19, 2003
    905
    Darryl
    You'll post if interested, please post pictures.
    Thanks.
  3. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    #28 mike01606, Jan 7, 2013
    Patience!
    A guy called Demon on another forum started me off down this road using cloths inside the unit and we have taken it from there.
    The first 6 pictures show how to make the final version of the wiper. The addition of the ice lolly stick and foam give a strong pad to wipe around the inside of the light. Without these, these magnets slide around inside the bag.
    The magnets are the super strong neodymium ones I bought off eBay. It would be better still to put magnets on each side of the stick as even with the strength the distance is limited.
    The foam is just some packaging foam that was lying around.
    The bag is a glasses bag (from cheap Costco reading glasses). Anything will do as long as it is non shedding and will not drop any of the bits inside. I tied it properly shut.
    The access is via the inner most bulb hole and a tip is the roll the pad and insert into the hole but before it goes fully in, make sure it is not too tight so it will definitely come out again.
    The bag must be tied onto a piece of nylon non-shedding string so you can pull it out. Be warned, these magnets are strong and the bag does latch onto metalwork below the lamp unit.
    The technique is to push the wiper to the front of the unit with a short wooden dowel then pick it up with another magnet on the outside wrapped inside a cloth (so as not to scratch the outside of the lens) and wipe the inside clean.
    I used detail spray on one side of the wiper with the other side dry for drying. For light dust marks you probably need only the wiper.
    For the place where the cover and unit are very close together I used no foam in the bag to clean the dust away (see last two pics).
    With a bit of patience, playing around and making sure everything is secure (otherwise you will be splitting them) you can pretty much get to anywhere.
    The results.
    My units had water marks in both sides and the right one was particularly bad. I took some befores but it is hard to get them to show up on a picture. Many who looked at the car tried to wipe them and usually asked what it was. Now there is nothing that is noticeable.
    I hope it works for you.........M
  4. tr328
    Jun 19, 2003
    905
    Darryl
    Mike,
    Thanks so much for posting the pictures. Very creative! Great job.
  5. mzappone
    mzappone Rookie
    Dec 4, 2007
    13
    Sarasota
    Michael Zappone
    #30 mzappone, Dec 9, 2013
    I have just sent my lights out after attempting to do this project myself. They came out amazing. The challenge with removing the lens cover is that it is glued on both sides. See photos. Ideally you would need a U shaped knife to cut them off without risk. Additional I was told that the manufacture uses a very small pin in a random location to hold the lens in place while the adhesive is drying. If anyone is looking to send their lights out I used Ferrari of Huston contact Steve Egyed Phone: 713-772-3868, Email: [email protected]. Steve does not cut the lens he cuts the light open so there is no risk of the lens cracking. It is cut in a place where the gasket covers when its installed (not visible at all). The piece was sent to me by Steve it is not from my light, he had a piece from a damaged light that he sent to help explain.
  6. zipperkarting
    zipperkarting Formula Junior
    256
    Jersey & France
    paul troalic
    Great job on the lenses but do you or does anyone know how to re-chrome the headlight bowls. Mine are not in brilliant condition with the yellow showing through.
    Can anyone help please?
  7. jackgt
    jackgt Formula Junior
    Jan 27, 2015
    574
    california
    Jack
    another source of strong magnets is out of old hard drives--
  8. KKALE
    KKALE Rookie
    Sep 1, 2015
    25
    usa pa
    kenneth kale
    can you tell me what you used to reseal the lens also i was told a little heat from a heat gun helps any word on that
  9. KKALE
    KKALE Rookie
    Sep 1, 2015
    25
    usa pa
    kenneth kale
    As i read firer i see you didn't seal them
  10. Brianvb
    Brianvb Rookie
    Nov 3, 2014
    1
    I took my headlights apart . After removing parts, Put in oven at 325 for 15 minutes, they come apart fairly easy. The grey material softens. Clean the lens , polish them, then clearcoat them on both sides. I also repainted the color on the housing. To reglue use RTV clear silione. The lenses are very durable. Mine turned out excellent and saved thousands. The clearcoat will extend the clarity of the lenses.
  11. djjvr
    djjvr Karting
    Aug 16, 2014
    117
    SFO/SAC/CPH
    So when you baked them did they still need to be cut out or could they just seperate? How difficult was the material at that point?
  12. douglas360
    douglas360 Karting
    Nov 7, 2016
    238
    SoCal
    Ugh, sorry to resurrect a zombie thread but just wanted to chime in.
    I tried the "magnet method" of cleaning the inside of the lens while in situ. Conclusion: Honestly, I think it's worse believe it or not. The problem is that there is no way to avoid picking up debris from inside the sealed unit (I tried cleaning out loose dust/debris before magnets) and that will leave micro abrasions in the plastic lens when scooting around with magnets.
    It's such a major buzzkill to look at these hazy and water marked lenses. I'm ready to pop the units out and send them to someone to pull apart, sand, polish, clearcoat, reseal, and return. I know my limitations and I just don't trust myself on DIY (I know I'll f**k up that operation and end up buying new units).
    Anybody aware of a shop in SoCal with experience doing this sort of thing?
  13. casey330
    casey330 Karting
    May 12, 2011
    107
    Huntington Beach, CA
    Casey Dalley
    I do them, here are a couple of my older posts
    http://www.ferrarichat.com/forum/360-430-sponsored-yellow-compass-group/452703-430-scud-carbon-fiber-headlight-restoration-project.html
    http://www.ferrarichat.com/forum/360-430-sponsored-yellow-compass-group/431812-360-modena-headlights.html#post143065769
  14. PableteM
    PableteM Rookie
    Feb 24, 2016
    11
    Good job! Thanks! what a shame! i could only read the DIY because i can not open the pictures!
    Anyone with this problem?
  15. Jacob’s toy
    Jacob’s toy Rookie
    Jun 18, 2019
    4
    Jacob Mesika
    Happy Independence Day.
    pilotoCS likes this.
  16. Jacob’s toy
    Jacob’s toy Rookie
    Jun 18, 2019
    4
    Jacob Mesika
  17. Jacob’s toy
    Jacob’s toy Rookie
    Jun 18, 2019
    4
    Jacob Mesika
    Can you fix mine?
  18. JRice360$pider
    Jul 2, 2021
    2
    Jeff Rice
    I recently had "Mr. Headlight Restoration Co." in Pennsylvania restore both of my headlights and it was such a good experience that I wanted to share it with the community. You can see in the attached pics that both of my lights had a heavy white film on the inside of the lens. These guys were able to take them apart, remove the film and put them back together good as new. The pics speak for themselves and the service was top notch. I was really nervous to send the lights out, considering they're $5k each to replace, these guys made me very comfortable with constant communication and updates pics along the way. I definitely recommend their services.
    https://www.mrheadlightrc.com/
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Makuono, Qavion and EastMemphis like this.
  19. CANDREAM
    CANDREAM Canada
    Nov 13, 2009
    407
    Burlington, Ontario
    Sadi
    Hello, any latest recommendations or shops that fixes this issue ? Is mrheadlightrc still a good recommendation ? Thanks
