Aussie Testarossa rebuild | Page 10 | FerrariChat
Discussion in 'Boxers/TR/M' started by uzz32soarer, May 1, 2012.
  1. uzz32soarer
    uzz32soarer F1 Rookie
    Sep 9, 2006
    3,090
    Melbourne, Australia
    Robert Hayden
  2. deangpsx8
    deangpsx8 Formula Junior
    May 2, 2008
    477
    Melbourne-Australia
    Dean C
    Since you now have so much experience, when you finish yours you can start mine.
    I have already done all the hard work
    New diff
    New shaft
    New belts
    So it should be a breeze for you.
    And I'm only around the corner too, so I can keep an eye on you.
  3. Melvok
    Melvok F1 World Champ Owner Silver Subscribed
    Jul 25, 2008
    14,295
    Mel
    Should be between 0.8 and 1.8 I believe: how much was it in this case Robert ?
  4. uzz32soarer
    Sep 9, 2006
    3,090
    Robert Hayden
    Can't remember Mel, Just on the tight side of the settings in the manual.
    0.12mm to 0.17mm from memory.
  5. uzz32soarer
    Sep 9, 2006
    3,090
    Robert Hayden
  6. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    Rob, dont ever, ever, ever take it out in the rain again :D
    P
  7. uzz32soarer
    Sep 9, 2006
    3,090
    Robert Hayden
    Frankly Phil, I'm actually starting to bother myself.
    I don't know what I'm going to do with it. makes a nice garage ornament at the moment though.
    It's a joy to build something that you don't even need to wash your hands after a few hours work though. With everything just brand new, it's a great feeling.
  8. uzz32soarer
    Sep 9, 2006
    3,090
    Robert Hayden
    Okay guys. I have a question.
    This picture from Eurospares below. Is this what the handbrake arrangement looks like on a LHD Testarossa?
    I was looking for a reference picture today for assembly of the lower control mechanism that operates the handbrake so I could understand if there was a reversed way that it could be fitted, and also which was to orientate the hook.
    I came upon this picture, but my three RHD cars look nothing like this. The long side goes through a tube welded through the middle of the chassis rail.
  9. uzz32soarer
    Sep 9, 2006
    3,090
    Robert Hayden
    And here's another picture. Does it matter which way you orientate the upper screw adjuster or the lower pivoting arm. On the bottom, should the lower adjuster have the pivoting pin towards the rear of the car or the front of the car?
  10. Melvok
    Jul 25, 2008
    14,295
    Mel
    Never gone so far yet Rob ! sorry .... ;)
  11. shmark
    shmark F1 Rookie
    Oct 31, 2003
    2,968
    Atlanta
    Mark
    I just read through every page and am thoroughly impressed, just had to congratulate you. Very very nice job, massive kudos for taking it on. That first drive will be well worth the effort.
    I plan on joining the TR community at some point, and I'm not sure if you're encouraging me or scaring the crap out of me! :D
  12. uzz32soarer
    Sep 9, 2006
    3,090
    Robert Hayden
    Bit of both Mark.
    Be wary of the diff issue. If you have the funds to take the risk, then just drive it. If you can see yourself spending 30 or 30 grand on something better than a diff rebuild, then put in a diff and quill shaft at your very first opportunity, and then go drive the hell out of it. They are great cars once the diff issue is sorted and out of your mind.
  13. Melvok
    Jul 25, 2008
    14,295
    Mel
    Found one picture in table 34 of the OEM Parts Catalogue (seem sto be the same as Eurospares) ..... so looks O.K. in your car now ... ;)
  14. dmaxx3500
    dmaxx3500 Formula 3
    1,027
    great job,keep the great work,then drive the hell out of it,they were built by people that only wished they could someday be able to get enough money that they could buy one too
  15. deangpsx8
    May 2, 2008
    477
    Melbourne-Australia
    Dean C
    Knowing rob it will be another garage queen after all this effort.
    But there are another 2 waiting to get the same treatment. Isn't that right Rob?
  16. Red Head Seeker
    Red Head Seeker Formula 3 BANNED
    Apr 27, 2009
    2,443
    San Francisco Area
    Mark
    WOW!!!....is it just me?!....or does the gear mating look very poor in the drive shaft flanges, as in...not very deep, Mark
  17. Steve Magnusson
    Steve Magnusson Two Time F1 World Champ Lifetime Rossa
    27,003
    The male splined shaft has a 45 deg chamfer on the OD at the end -- so that makes the male teeth look much shorter in that photo (where you only see the end plane of the male shaft). See the photo in post #10 of this thread for a pic of the male splined shaft alone.
  18. Red Head Seeker
    Apr 27, 2009
    2,443
    San Francisco Area
    Mark
    Hello Steve; ...& as always THANKS!!!...I glad you understood what I was Seeing(?), as it appeared that the total gear meshing surface ratio was very small....Have a GREAT 3 day weekend, & to ALL!!!.....Mark
  19. uzz32soarer
    Sep 9, 2006
    3,090
    Robert Hayden
  20. Marty
    Marty Karting
    Nov 21, 2003
    108
    Boston/PTown/SW FL
    Martin Stark
  21. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    Boy, thats a big Carburettor :D
    P
  22. Melvok
    Jul 25, 2008
    14,295
    Mel
    Comprex compressor ?
  23. uzz32soarer
    Sep 9, 2006
    3,090
    Robert Hayden
    That's an Eaton M90 which I have on a 4.0 Lexus V8. It's a spare that I had on the shelf but it was just a test fit to see what things looked like.
    I'll be using a Kenny Bell water cooled or a Whipple twin screw. Both are latest technology and run much cooler.
    I'll be fitting it to a 512M engine with fully controlled injection and then lowering it into the back end of the Testarossa.
    Bu first things first, I have to get the red beast back on the road, and then divert attention to that next project on my blue 88 model.
  24. Melvok
    Jul 25, 2008
    14,295
    Mel
    Opened it for you Robert .... rh side 512TR ;)
    Any help ?
  25. uzz32soarer
    Sep 9, 2006
    3,090
    Robert Hayden
    Can you photo the bottom mechanism please Mel?
    That photo shows the top adjuster well, but the bottom can face in either direction and a photo of that would help.
