Computer interface for TR? | FerrariChat
Discussion in 'Boxers/TR/M' started by rpissm, Apr 2, 2014.
  1. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    Anyone know of a way to hook up to the TR computer / ECUs and get an understanding of the data that's available?
  2. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,648
    Land of Slugs & Moss
    Han Solo
    Because the TR is not OBDI or OBDII it doesn't have a central computer, therefore, no real data or stored codes..
    The easiest way to get a look at how all of the systems (fuel/air/spark) on the TR are doing is hook it up to a diagnostic scope. (I'm not talking about a code reader).
    You can observe the health of all the systems in real time while the car is running.
    Just about any shop has one and all dyno shops have them.
    I seem to recall a port under the LH fender that was available for some sort of Ferrari diagnostic tool (back in the day) but from what I remember it didn't do as much as one of today's scopes.
    Rifledriver can answer the question far better than I.
  3. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,128
    Mel
  4. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    You are referring to the Jofatron K8S, which connects to the port over the LH wheel arch on some (not early, not late) Testarossa. As I recall this was essentially a (very expensive) breakout box. Shops in my area don't use them (don't even have them).
  5. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    Thanks for the info. What kinds of at-home scopes are available for the casual garage hobbyist? Will any one do or I'm assuming I'd need one that can handle 12 cylinders?
    Sent from my Nexus 10 using Tapatalk
  6. Steve Magnusson
    25,157
    The Jofatron is only for the (TR MicroPlex) ignition system -- for the KE-Jet injection system, it's the 25-pin breakout box, Diagnosis Sheet No.6 (corrected), and a voltmeter ;)
  7. Jaguar 15
    Jaguar 15 Formula 3
    Mar 27, 2013
    1,837
    Hunt. Bch/Palm Dsrt/Virginia
    Jim Crawford
    As someone that is pretty hands on mechanically and electrically, I'd be reluctant to mess with all that unless I had a problem. Is that box or any of the electronic boxes something that should be played with unless you REALLY knew what you are doing? One minor slip crossing wires, you fry a hard to get and expensive "something".
  8. okiedude
    okiedude Formula 3
    Jul 11, 2011
    1,013
    Remulak
    Blake
    No Canbus plug, rats!:)
  9. Spasso
    Feb 16, 2003
    14,648
    Han Solo
    Yes, thank you.
  10. Rifledriver
    34,138
    Austin TX
    #10 Rifledriver, Apr 6, 2014
    It is not in any way a break out box.
    And actually, yes, there are a few around the area. But as for using them you might be correct. They were pretty worthless. We always called them the Jokeatron.
  11. Rifledriver
    34,138
    Austin TX
    There is nothing about either the ignition or fuel sytem that cannot be diagnosed and serviced with pretty simple over the counter diagnostic tools. If it is a version with the KE fuel system the best money that can be spent is on a good Bosch book describing the theory and operation of the system. Once you know that there is very little that cannot be done with a VOM and a set of pressure gauges. In reality it has been such a relable system there is little chance you will even need that. The piece of equipment I use more than any other for service and diagnostics for the K and KE system is a 4 gas exhaust analyzer.
  12. Jaguar 15
    Jaguar 15 Formula 3
    Mar 27, 2013
    1,837
    Jim Crawford
    For my '71 Mercedes 3.5 coupe, which has the Bosch D-Jetronic injection system, I copied a Bosch fuel system manual off the internet. It covered the various systems...D, K & KE . I'll try to find the link.
  13. okiedude
    okiedude Formula 3
    Jul 11, 2011
    1,013
    Remulak
    Blake
    Brian, thanks for the input. That is reassuring!
  14. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    Thanks for the info everyone! And Jaguar 15 if you do find that link I'd appreciate it if you let me know.
  15. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    Awesome! Thanks!
