CV Boot replacement on 355 | Page 2 | FerrariChat
Discussion in '348/355' started by TrojanFan, Feb 22, 2014.
  1. johnk...
    johnk... F1 World Champ Owner
    Jun 11, 2004
    11,300
    CT
    John Kreskovsky
    I can not imagine why you would vent a CV boot on a street car.
  2. TrojanFan
    TrojanFan F1 Veteran Owner Silver Subscribed
    Nov 17, 2008
    5,208
    So. CA & NV
    Peter
    I just watched the YouTube video showing changing the CV Boots on a 348. Should the 355 be a very similar procedure?
  3. fatbillybob
    fatbillybob Two Time F1 World Champ Consultant Owner
    Aug 10, 2002
    29,483
    socal
    I have never done it on any race car either. I guess under certain conditions there could be a benefit.
  4. GarageWarrior
    GarageWarrior Karting
    Aug 15, 2013
    93
    Westerly, RI
    Bolts that hold CV joint to the flange are critical and take a lot of torque for they size. If you don't get them tight they WILL come loose. I had to redo mine which involved a tow truck.
  5. jochem00
    jochem00 Formula Junior
    Jun 19, 2014
    344
    Netherlands
    does the complete drive shaft have to be removed for changing the inner boots?
    or can it be done with unbolting the inner cv joint bolts, move the shaft to the rear, undo the circle, slide cv joint off, put new boot on and put everything back into place!
  6. Challenge
    Challenge Formula 3
    Sep 27, 2002
    2,027
    PA
    Kevin
    You want to pull the entire half-shaft. Trust me.
  7. 355rockit
    355rockit Formula Junior
    Dec 1, 2010
    894
    San Marcos, CA
    Vas
    I had a Porsche CV joint boot installed on the right since I heard they would fit and was much cheaper. The boot didn't last more than a week before it ruptured (looked like it exploded) and spread grease around. Not sure if it was the installation or it couldn't take the heat. I had the OEM boots installed and all has been well the past couple of years. I also put better heat shielding over the CV joint boots which helped greatly.
  8. Dino Chang
    Dino Chang Guest
    Dec 29, 2012
    772
    Agreed, i have always reinforced my heat shields to.
  9. Andy 355
    Andy 355 Formula Junior
    Jun 2, 2013
    434
    I fitted the pegasus shielded boot as recommended by f.chat. Great fit,great price and superior to stock.
  10. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Any more info on this?
    I've never heard of it.
  11. taz355
    taz355 F1 Veteran Owner Silver Subscribed
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    I replaced them all this year because they were a terrible pain in the ass to get off. I took the whole shaft out and did both ends. The company I bought them from they fit perfect but what a pain. The big ends were no problem it's getting the small ends over and then crimping them.
    All I can say is I hope my new ones last another 15 years.
    I can not remember the name of the company it's like NE usa and the kit was 90 dolaars four all four.
  12. jochem00
    Jun 19, 2014
    344
    Netherlands
    you can slide the CV joint of the shaft. so no need to pull the boot over the CV joint at all.
  13. LmnsBlu355
    LmnsBlu355 Formula Junior
    Dec 28, 2009
    284
    NY
    Jordan S.
    I did it this way. Messy and a pain in the azz. Next time would just pull the whole axle. But yes it can be done.
  14. Andy 355
    Jun 2, 2013
    434
  15. WJGESQ
    WJGESQ Formula 3
    Dec 30, 2004
    1,477
    Funny post.
