Engine out major service, and now no spark or fuel | Page 2 | FerrariChat
Discussion in '348/355' started by User-C3, May 23, 2019.
  1. User-C3
    User-C3 Karting
    Aug 29, 2018
    240
    Detroit
    Trevor
    here is the wiring I removed out of the trunk. I will snap a pic of the wiring from the head unit. Checked all that 2 nights ago and couldn't see anything that would of lead me to believe it was that.
    and you can see in the second photo the wire taped up where they had spliced into power.
  2. User-C3
    User-C3 Karting
    Aug 29, 2018
    240
    Detroit
    Trevor
  3. User-C3
    User-C3 Karting
    Aug 29, 2018
    240
    Detroit
    Trevor
    quadruple checked all grounds and connections last night, nothing is unhooked. Going to clean the crank sensors and use a jumper wire to bypass the fuel pump relays to ensure the pumps are not the issue.
    Bertil likes this.
  4. User-C3
    User-C3 Karting
    Aug 29, 2018
    240
    Detroit
    Trevor
    Never noticed, but now I see I have no interior power. No headlights, no running lights, no HVAC, no Windows etc. Bypassed the fuel pump relays, and the pumps turn on. Its weird that I can turn on the ignition, hear the brake pump and some other electrical noise in the front passenger side and the engine will crank.
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,674
    San Carlos, CA
    Mitchell Le
    My guess is when you removed the after - market wiring at the front, you accidentally removed a major power feed to the car. That wiring mess at the ABS controller board is really messy and convoluted, and it is also a point where many after market installer will tap power.
    Find that power feed missing and you will solve your problem. It is not something mechanical related to your engine work.
    ernie and taz355 like this.
  6. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Audio Installers = splice & dice monkeys. Irks me every time I see stuff like that.
    ernie, taz355 and Robb like this.
  7. Qavion
    Qavion F1 World Champ
    14,538
    Ian Riddell
    #32 Qavion, May 24, 2019
    The brake pump uses battery and ignition lock accessory wiring/power. The starter, of course, uses the ignition lock start wiring. It seems you have a problem with the ignition lock run circuits.
    It's hard to see where they spliced in the stereo equipment in your photo, but it's so far away from the ignition key source, I wouldn't think it would cut off the whole ignition system. Don't discount a random relay failure. e.g. relay "e" in the passenger footwell controls a lot of the ignition powered systems (lights, HVAC, windows, etc).
    Pull out relay "e" and see if you are getting ignition key power to the relay coil (pin 86) when the ignition key is in run. Also look for constant battery power on pin 30. If they are good, fit the relay and turn the ignition on and off to see if the relay clicks. Then we can work downstream to individual items. However, unless you've blown lots of fuses, I can't see how all the systems you've mentioned could stop working.
    These inoperative systems also have lots of different earths, so I don't see how an earthing problem would take out all these systems (unless it was the earth for relay "e" labelled "100" in the wiring diagrams. I'm not exactly sure where that is. It could be one of those earths behind the passenger footwell relay panel (There is an earthing point there which looks like a porcupine it has so many black wires attached to it).
    The following diagram (one of many) shows the ignition switch, relay "e" and earth "100" :
    F348 Windows Wiring Diagram
    There are variations in how the big blue wire gets to the relay panel, so that's why you should check relay "e" contacts first. Also, it's easier to check the volts on the relay than it is to pull the relay panel apart and check the plugs on the back.
    There is a previous thread on the forum in which a 348 owner found a problem with the blue wire between the ignition lock and the passenger footwell relay panel (he removed an alarm system and I think the wiring wasn't connected back up correctly).
    ernie likes this.
  8. Qavion
    14,538
    Ian Riddell
    Just an afterthought. The ignition key run/on power to the engine management wiring doesn't even go to relay "e", so the problem may indeed be further upstream than relay "e". That is, the wiring from the ignition key to the footwell relay panel.
    Anyway, relay "e" is a good starting point. You can also test continuity between the steering column electrical plug and relay "e" pin 86.
  9. m.stojanovic
    m.stojanovic F1 Rookie
    3,300
    Serbia - Niš
    Miroljub Stojanovic
    This is an extract from Ian's diagram. Do the basic check first at the relay panel in the boot:
    1. Do you have permanent 12V supply at the fuses 3, 4 & 15
    2. With the ignition "on", do you have 12V supply at the Blue/Red wire (marked as "IGN PWR")
  10. Qavion
    14,538
    Ian Riddell
    #35 Qavion, May 24, 2019
    Sorry, the more I look at these diagrams, the more the problem seems to be between the ignition lock and the footwell relay panel. Does your fuel filler cap button work with the ignition in run/on?
    (EDIT) Miro, the windows actually use relay "g" in the footwell, so it must be upstream of the luggage compartment. The lights use relay "e". Relay "p" for the fuel filler cap will put the power problem well upstream of the luggage compartment panel.
  11. m.stojanovic
    3,300
    Serbia - Niš
    Miroljub Stojanovic
    I based my suggestion on the fact that the Blue/Red wire to the luggage compartment fuse/relay panel enables four relays for the lights (which are not working) - a, e, f & g and on the fact that the audio amplifier needs permanent and ignition switched supplies which may have been taken from the lines to this relay panel and now, after the audio wiring removal, something is disturbed.
  12. Qavion
    14,538
    Ian Riddell
    #37 Qavion, May 24, 2019
    I see. What about the running (side) lights? These use relay "b" in the footwell. I suppose the wiring disturbance in the luggage compartment still could have affected these (but perhaps only at the front... unless something is shorting, taking out all of them)
  13. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,448
    Tucson, Arizona, USA
    Robb
    I feel for you and hate the stereo hacks from back in the day. I’m sure you’ll track it down.
    Robb
  14. m.stojanovic
    3,300
    Serbia - Niš
    Miroljub Stojanovic
    I can see that the HVAC pressure switch sends a signal (+12V) to certain pins of both engine ECUs which is to slightly increase the idle speed and compensate for the load by the AC compressor. Try to start the engine with the AC pressure switch and the line to the AC compressor clutch unplugged, just to eliminate the possibility of the engine ECUs being affected by something wrong in this part of the HVAC system.
  15. Qavion
    14,538
    Ian Riddell
    Trevor, let us know if we are overloading you with information :p
    I'm happy with just the fuel filler lid test (It will tell me if you are getting ignition power to the footwell relay panel which will affect sidelights, HVAC, windows, engine ECUs... and possibly headlights depending on how your car is wired up.
  16. Qavion
    14,538
    Ian Riddell
  17. 355OXO
    355OXO Karting
    Apr 16, 2006
    204
    Simon
    Have you got the wiring loom to the coil packs round the wrong way?
  18. Qavion
    14,538
    Ian Riddell
    The problem is a bit deeper than that, Simon. Trevor's window motors and lights are not even working.
    The black tape in the luggage compartment appears to wrapped around the pink and red wires coming from plug 103 in the following ABS diagram. i.e. battery power directly from the footwell battery bus bar.
    F348 ABS System Wiring Diagram
    Since the brake pump is working, we can assume that that wiring is ok.
  19. User-C3
    User-C3 Karting
    Aug 29, 2018
    240
    Detroit
    Trevor
    I found the thread about the owner who had the same type of problem after the car sat all winter. Sounds exactly like whats happening to me. I'm going to test the blue wire from ignition to footwell fuse panel that ended up being his problem with an alarm system. There could be an alarm on this thing that im just unaware of causing my issues.
    This is all really great info, and I'm very appreciative of all the thought and time by everyone. Will consider everyone's suggestions and do some more exploring and report back.
  20. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Try to hot wire it to get it running, if it runs back track until you find the issue.
    If it dont run then a wire or 2 are in the wrong place or one of the connecting wire plugs one of the pins get pushed out
  21. Qavion
    14,538
    Ian Riddell
  22. radlu
    radlu Formula Junior
    Jun 6, 2005
    424
    Maybe your were getting fuel and plugs are fouled now. Remove and inspect.
  23. Koenig1
    Koenig1 Formula Junior
    Aug 25, 2016
    328
    Ottawa ON
    Sandy
    #48 Koenig1, May 25, 2019
    EDIT: thought it was alarm removed, reread, was stereo system.... but I think same 'power feed' applies
    Edit #2: I think starting with the key switch output(powering everything) will be the wire that's been 'cut' is the right start...
    My .02 bet... The installer used a major power feed wire, cut it to tap/power into his alarm. The other end of said (cut)wire was spliced to one of the alarm output wires, thus 'completing' the circuit. When you cutout the alarm, said 'cut' power wire is now disconnected, and will require a length of same gauge, spliced to both ends.
    2 ways to find...
    a) look for a single wire cut out (same color, hopefully) at both ends. Test for power at least 1 end.. Splice back...
    b) Download wiring diagram of said alarm, and trace those ends. Perhaps if lucky, the install instructions will offer a clue to which. If most power is not there, it will usually be a larger gauge feed!
    carnutdallas, taz355 and Qavion like this.
  24. TaureanDragon
    TaureanDragon Karting
    Nov 16, 2014
    52
    Herts, UK
    Not had to debug this kind of problem on my 348 and am probably not as clued up as some of the others on here, though I’d like to think I understand the basics enough to share some thoughts.
    Firstly, my understanding of the problem:
    No Spark - Am assuming this has been verified, at least at the ignition leads and on both banks. Not sure not starting on fueling through the intake would be verification of this. (Though starting via this mechanism would confirm a spark was present :))
    No Fueling – Dry Fuel Line and Filter. (Could be the pump is not pumping or the fuel line is blocked).
    The Crank Sensors were not removed, therefore should not have been disturbed.
    The Cams were taken out and replaced with new seals and gaskets
    – Did the CAM sensor get disconnected? (Though if the CAM was left disconnected I would expect the system to fall-back to a crank only mode which would just take longer for the car to start. Though have never verified the 348 does have this as a fall-back on a CAM failure)
    – Did the CAMs get refitted correctly? (If the CAMs are fitted incorrectly and the CAM signal appears in the wrong place, the ECU will not be able to sync. In isolation, the Crank Signal will seem OK as will the CAM signal, however the relative position would be incorrect and the electronics will not know which signal to trust and therefore not sync. Though if the CAM was fitted incorrectly there would also be the possibility of a problem with Piston/valve clearance).
    If the ECU can-not see a crank/cam signal, or verify they are correctly synced, it will not be able to determine when to fire injection and fueling and not attempt to.
    Also, after the engine out, were the ECU’s reconnected the right way round?
    There’s no Alarm system fitted, so can’t be the cause
    You also state you have recently noticed:-
    - No interior power, No headlights, no running lights, no HVAC, no Windows etc but you also state that you can turn on the ignition, hear the brake pump and some other electrical noise in the front passenger side and the engine will crank.
    - Turn on the ignition and the brake pump and some other electrical noise in the front passenger side can be heard and though the engine won’t start, it will crank.
    Was it working and this started happening recently, or could it have been not working since the engine was refitted.
    (As the fuses are intact, and the devices on different circuits I would have thought this lack of electrical power would have been a common grounding problem, though I would have expected the engine to also not crank. I have a Ground Isolation Switch on my 348 which, when active, isolates the battery totally when active ie would also not allow cranking. Not having looked into the 348 wiring diagram with respect to this, I don’t really have any suggestions with respect to this bit and while the issues could be related, I’m not sure.).
    Would be interested to know the root cause When you get it identified.
    In summary, and in addition to the suggestions in the other posts,
    Have the CAMs' been refitted correctly? As this could cause an ECU syncing problem.
    Have the Two ECU's been re-connected the right way round?
    Is the ECU receiving a Crank and Cam signal?
    Good Luck
    T.D.
  25. User-C3
    User-C3 Karting
    Aug 29, 2018
    240
    Detroit
    Trevor
    I got it started!!!
    First off let me thank everyone for all the help and info. You guys are awesome.
    I started tracking wiring behind the dash, thats the only thing thats changed, removing the stereo mess. There was the loom that was the factory stereo plug, obviously cut and spliced for what they put in. Then there was a black and red wire wrapped up with an antenna cord. Heres a pic of those wires in the center console area. I figured these were a power ground to operate the power antenna and tracked them back to the power motor and antenna. I decided I would put direct power and ground to them from the battery and make sure they operated the antenna. Connected a ground to the black wire and heard all kinds of footwell panel activity. The battery was disconnected while doing this and the key out. Took the connection off, plugged in the main ground connection and had power to everything, headlights, Windows, HVAC, etc. Turned the key and it instantly fired up and ran.
    The only thing I can think is perhaps doing that I reset something. Maybe you guys are better informed on what did happen. It starts, it runs, I'm pumped. Happy memorial day.
