HELP, PLEASE! 348tb alternator upgrade | Page 4 | FerrariChat
Discussion in '348/355' started by Lars Ljungstrom, Aug 11, 2019.
  1. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  2. Jasonberkeley
    Jasonberkeley Formula 3
    1,348
    NW Corner, CT
    Got it- thank you. Will definitely need to work on a heat shield once winter gets here.
    In the meantime, if oil had been getting into the alternator, if I spray it thoroughly with the electric contact spray, should the problem (if that was the root cause) be cleared-up if cleaned thoroughly enough, or does the oil cause a permanent problem?
  3. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I see videos where people clean them and there is no issue after. In your case its hard to say, if the issue is a component got damaged then cleaning it wont help. Give it a shot!
  4. m.stojanovic
    m.stojanovic F1 Rookie
    3,331
    Serbia - Niš
    Miroljub Stojanovic
    The only part of the alternator that can be affected by oil and cause malfunction are the carbon brushes and the slip rings. If they are contaminated with oil, I don't think spraying from outside will "wash" them. I would remove the alternator cover and spray directly to the brushes/rings if found oily.
  5. 26street
    26street Formula Junior
    Jan 30, 2021
    473
    Westchester New York
    Mark k
    Hi there is a great rebuilder “bronx ignition 1424 blondell Ave Bronx ny 10461”
    These guys are the best and can answer any questions you have most of the northeast dealers use them and they will let you know exactly which and what alt will work
