How to get rid of Check Engine Light for Cats on 360? | Page 2 | FerrariChat
Discussion in '360/430' started by arachnyd, Aug 18, 2018.
  1. cpep
    cpep Formula Junior
    438
    new york
    CHARLIE
    Most states will let you have up to two not ready as long as one of them is not the cat. Most shops cant be bothered with a visual by me. Time is money and as long as it passes they couldn't care less how you did it.
  2. Walt Gamble
    Walt Gamble Formula Junior
    May 22, 2014
    426
    Ok I read with interest the technical details....now for the Rube Goldberg fix? I created a tiny prancing horse sticker that blanks over the CEL (mine relates to the vapor recovery sensor) If I strain I can still see the light especially if it flashes. Every so often I read the codes to be sure. My heirs will have to deal with it...I warned you a hokey fix.
    Sent from my XT1058 using Tapatalk
  3. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,156
    San Diego CA
    Fernando
    All monitors get completed in my car and the smog technician didn’t say nothing about my headers nor my 02 extenders. The visual inspection is a matter of luck,I don’t know anyone who has been failed due to headers, cats yes all the time but not headers (honestly how many technicians are familiar with precats inside headers?)
  4. cpep
    cpep Formula Junior
    438
    new york
    CHARLIE
    I might do the same but it would still fail in my state because they plug into it. But if you don't have emissions testing that would work. As long as you don't end up with another issue that you ignore thinking its the o2's.
  5. Skidkid
    Skidkid F1 Veteran
    9,646
    Campbell, CA
    John Zornes
    Ok. So you managed to get by smog this time but that is no guarantee for any future test. The car is not smog compliant and technically a cop can ticket that. Everyone can do what they want but ‘I got mine through’ is not the same as ‘the configuration passes CA smog (read legal)’.
  6. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,156
    San Diego CA
    Fernando
    True but you said “won’t pass smog” like a technician would automatically fail the car (like with cats) and that is not strictly necessary.
    I don’t think a cop would know about precats if even smog technicians are not aware.
    It is that route or buying OEM headers that will keep failing OR hollow the original headers that it is also “illegal”
    So the only 3 options are:
    1 buy new OEM headers ($$$$) and repeat in the future.
    2 aftermarket headers with 02 extend extenders and cross fingers every 2 years
    3 hollow the original headers
    2 and 3 are technically “illegal” but also the front license plate.
  7. Dewinator
    Dewinator F1 Veteran
    7,749
    WA
    Have people who just hollowed the original headers with OEM cats mostly been getting CELs?
  8. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,156
    San Diego CA
    Fernando
    Well two things here
    The idea of replacing the headers is to prevent the precat failure.
    That fix comes with a compromise, you might get CELs si installing 02 extenders or mini cats is a solution that most of the time works but sometimes it doesn’t. OR you could install brand new OEM headers (very expensive and that will fail for sure in the future)
    There is no free lunch about this
    G. Pepper likes this.
  9. Dewinator
    7,749
    WA
    If I did the Fabspeeds, I would want to have that metal heat shielding welded over them, but I think it’s dumb that they don’t come that way. So I think I’ll just have mine hollowed and then try the sensor extendors if I get CEL... fortunately I’m a WA resident so no emissions testing.
  10. arachnyd
    arachnyd Karting
    Feb 5, 2016
    129
    Springboro
    Based on exhaust diagrams, there's 2 C0 Sampling Unions (OK so maybe those aren't O2 sensors... ) and 4 02 sensors (2 after the precats and before the actual cats and 2 after the cats)
    So maybe its just 4. Even if its 4, which ones do I put the extenders into?
  11. cpep
    cpep Formula Junior
    438
    new york
    CHARLIE
    The rears. I put a set on last week and when i just checked it everything is satisfied. But it also went about 300 miles last time before it picked up an o2 code so we will see. I bought the straight mini cats and 90 deg elbows but only have the straights on the car right now.
  12. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    My solution does not require any 'dongles' fitted. It actually software which alters the behaviour directly in the software of the ignition computers themselves so it won't ever generate a CEL for catalyzers ever again, you can in effect run test pipes and you wont get a CEL. It in effect disables the 'feature' to trigger the CEL itself and then you reflash your ignition computers with the 'patched' versions.
    I'm doing it so it can be enabled/disabled features any time you want, first prototype testing is already ongoing. Won't be long now boys!
    arizonaitalian likes this.
  13. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,156
    San Diego CA
    Fernando
    “2 after the cats”
    Only if your car is a 99, otherwise the downstream (rear) 02 sensors are connected to the cats in the middle, after the first set or cats inside the main Catalytic converter but before the bigger ones.
    You should take a look at the thread I copied the link
    All the info you need is there.
  14. one4torque
    one4torque F1 Veteran
    5,794
    Houston
    One4torque
    360trev - keep us posted. Thx.
  15. one4torque
    5,794
    Houston
    One4torque
    Oh yeah.. also keep in mind after 25 yrs old in tx... no emmissions testing.... just safety. counting down the years.
  16. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner
    Jan 19, 2004
    7,878
    San Jose, California
    I had this problem (CA car), tried all of the inexpensive fixes, no luck, replaced the exhaust manifolds from an auto wrecker with a 360 with 25K miles on it, fixed.
  17. bisel
    bisel Formula 3
    1,138
    Scottsdale, Arizona
    Steve Bisel
    I started a thread on this same problem ... https://www.ferrarichat.com/forum/threads/p0421-p0431-trouble-codes-catalytic-converter-anyone-have-good-fix.552866/
    I have had about 4 months now of driving without any CELs.
    My set up:
    • Fabspeed headers
    • Stock cats
    My issues:
    • P0421/P0431 codes ... warm up catalyst efficiency below threshold
    • P0159 code ... O2 sensor circuit slow response Bank 2, Sensor 2
    My fix:
    • Purchased two mini cats from Big Daddies Garage
    • Purchased two right angle extenders ... note, the Big Daddies extenders will not allow you to thread onto the bung without pulling the catalytic converter
    • Purchased two extenders
    The mini-cats are installed with a right angle extender ... https://www.ferrarichat.com/forum/threads/p0421-p0431-trouble-codes-catalytic-converter-anyone-have-good-fix.552866/page-18#post-145878835
    This fixed the P0421/P0431 codes, but after a bit got the P0159 code.
    I cleared the P0159 code and it has not come back. Cannot say with certainty that it is 100% resolved, but so far no codes for P0421/P0431. I am keeping fingers crossed.
    Steve
  18. arachnyd
    arachnyd Karting
    Feb 5, 2016
    129
    Springboro
    Here's a question no ones asked... Why doesn't anyone just convert their system to euro specs?
    Good to know, thanks! Mines an '01.
    If there's only one set though then its pretty straight forward.
    Unfortunately I don't see a thread you linked?
  19. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,156
    San Diego CA
    Fernando
    #44 ferralc, Aug 20, 2018
    It is the post 17, Bisel also posted it above
    We discussed it very thoroughly months ago and honestly I don’t know why it didn’t become a sticky
    Every single one solution is listed there
    When I quoted your “2 after the cats” I meant the word “after” but you still have two sets, one at the headers (upstream) and one at the middle of your cats between the first and second sets inside your main cats (you will understand when you see the thread and the pictures I posted there) but you still have 2 sets of 02 sensors in your model.
  20. arachnyd
    arachnyd Karting
    Feb 5, 2016
    129
    Springboro
    OK thanks.
    Sad thing is I even searched before I posted... Searched the CEL codes, and was surprised to find nothing except for a post about exhaust clamps and tubi test pipes...
  21. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,156
    San Diego CA
    Fernando
    Search tool is a PITA after the upgrade
    Take a look at the thread everything is there trust me
  22. Hypek9
    Hypek9 Karting
    Apr 9, 2012
    162
    Australia
    An aftermarket muffler should not throw a CEL, headers maybe a different story. Custom tune is not a big deal at all, had mine done much improved throttle response and low to mid power. Check out auto racing technik in heidelberg. Tunes a lot of Ferrari’s and tubi authorised shop. Alvin tuned my 360
  23. JonM
    JonM Karting
    Oct 31, 2017
    132
    South Gippsland, Victoria, Australia
    Jon Maratos
    As far as I know, I've only got an aftermarket muffler.... What did it cost for the tune, if you don't mind me asking?
  24. Hypek9
    Hypek9 Karting
    Apr 9, 2012
    162
    Australia
    $2.5k off the top of my head. Alvin can do your major as well at the same time!
    JonM likes this.
  25. sparetireless
    sparetireless Formula 3
    Nov 2, 2003
    1,596
    Set up your O2 sensors in same locations as a 99 model. It will pass smog and no light.
