360 - Inter-ECU CAN Bus Wiring | Page 2 | FerrariChat
360 Inter-ECU CAN Bus Wiring
Discussion in '360/430' started by Qavion, Apr 30, 2025.
  1. mello
    mello F1 Veteran Silver Subscribed
    Jul 12, 2013
    5,551
    CA Bay Area
    Steve
    Thanks for the PDF. It's good info. A few things comes to mind immediately, but I want to chew on it a bit.
    As to the CAN ID that you're only interested in... is that the master node ID (e.g. ECU Bank1) or you meant to say, "I'm only interested in message ID x generated by node x"? Just curious.
  2. Black360
    Black360 Formula Junior
    Oct 11, 2010
    467
    East of Eden
    Glad it was readable.
    Great. A thoughtful comment is better for me than a quick comment.
    I'm not fully up-to-speed on CAN terminology, so I'll answer this way:
    I'm only interested in values of engine coolant temperature, as a function of time, generated by the temperature sensor, and transmitted via CAN bus to Bank 2 ECU.
    Let me know if that does not answer your question.
    mello likes this.
  3. Black360
    Oct 11, 2010
    467
    East of Eden
    Another way to put it:
    I assume that Bank 2 ECU is using engine coolant temperature (Tc) from the CAN bus to determine injector duration. I also assume that Bank 1 ECU is using Tc directly from the temperature sensor.
    Does the average value of Tc, used by Bank 1, differ significantly from the average value of Tc used by Bank 2?
    Also, is Bank 2 Tc variance large relative to Bank 1 Tc variance?
    I'm defining variance as the range of reported Tc values divided by the average Tc value.
  4. yelcab
    yelcab F1 World Champ Consultant
    Nov 29, 2001
    13,704
    San Carlos, CA
    Mitchell Le
  5. ItsAboutThatTime
    ItsAboutThatTime Karting
    Apr 7, 2024
    129
    Arvada, CO
    Shane
    My apologies. I got so caught up in trying to ensure my post didn't have any typos (mobile is super funky) that I put the wrong word in. Thanks for correcting that
  6. Qavion
    Qavion F1 World Champ Silver Subscribed
    Feb 20, 2015
    14,672
    Ian Riddell
    Does anyone have a list of the information travelling on the bus between the Motronic ECUs?
    We are primarily concerned with coolant temperature, but @eric355 mentioned coolant temperature is also sent on the OBD2 network.
    Immobiliser unlock signals are sent from the RH ECU to the LH ECU. That's ok because the LH bank injectors are working.
    Is MAF data sent between the ECUs? i.e. when air from both inlet manifolds is being fed into each bank at higher rpms.
  7. mello
    Jul 12, 2013
    5,551
    CA Bay Area
    Steve
    The problem that you've described in the observation section is something I've experienced in the past to solve a drive-ability issue. The STFT and LTFT numbers were corrected too often. I did remove the coolant temperature sensor and test it according to the workshop manual and was found to be not at fault. In the end, it was a combination of a loose air hose and a bad intake air temperature sensor that's in the mass air sensor. I hope this information is helpful.
    https://www.ferrarichat.com/forum/threads/diy-360-fix-your-maf-for-less-than-1-00.447868/page-2#post-143130772
  8. yelcab
    Nov 29, 2001
    13,704
    San Carlos, CA
    Mitchell Le
    Well, for less than $1 per thermistor, that is one cheap fix.
    mello likes this.
  9. Black360
    Oct 11, 2010
    467
    East of Eden
