oil cooler fan for a 328 | FerrariChat
Discussion in 'Technical Q&A' started by martinlaw, Mar 12, 2004.
  1. martinlaw
    martinlaw Rookie
    Nov 4, 2003
    12
    Hello Everyone,
    Has anybody fitted an electric cooling fan to the oil cooler (a very 'thin' fan).
    On track days the oil temperature is constantly going way too high and I figure a small fan sucking more air through the oil cooler may help the problem.
    Appreciate any advice.
    Many Thanks.
  2. chaa
    chaa F1 Veteran
    Mar 21, 2003
    5,058
    When i replaced my 328s cooler last year, i noticed the left hand side air scoop feeds air to the cooler. I dont think anymore air could be feed through the cooler with a fan that will be that small, as well as haveing the problem of refitting the shroud that encases the oil cooler. I think you should replace the cooler first with new and check the thermo stat.Or relocate with bigger cooler.
  3. Dave328
    Dave328 Formula 3
    Nov 24, 2002
    2,133
    Katy
    Dave
    This has been discussed here before. I have the same problem on my 328 when at the track. I think the problem lies in the fact that the cooler "cools" by the ram air effect through the scoop. However, at a track,you never have that constant velocity and volume of air that you would see while on the HWY at a steady 60+ because you are constantly off and on the brakes and gas and turning. A motorcycle riding friend suggested a MC cooling fan. He said he thinks Honda's use a 12v cooling fan on some of their bikes. This would be the size needed due to lack of room. As summer approaches, I'll have to investigate this further.
    Dave
  4. f355spider
    f355spider F1 World Champ
    17,940
    Looking at the diagrams, there is no t-stat on the oil lines on a 328. I don't think they use one on any of their cars...yet. Or do they?
    There are plenty of fans that you could arrange for a "puller" effect, that would work. The motorcycle option sounds good. I have a Kawasaki 600 ninja with a tiny thermostatically controlled fan for the radiator.
  5. Verell
    Verell F1 Veteran
    May 5, 2001
    7,017
    Groton, MA
    Verell Boaen
    Search the archives (Old Fchat Tech I think). There's a photo of a 'puller' fan installation from a year or so ago.
  6. 308 GTB
    308 GTB F1 World Champ
    11,193
    New Jersey
    Barry Wolinsky
