348 - Tricks for placing the belt ? | Page 2 | FerrariChat
348 Tricks for placing the belt ?
Discussion in '348/355' started by 348steve, Jun 26, 2019.
  1. ernie
    ernie Two Time F1 World Champ Lifetime Rossa Owner
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
  2. 348steve
    348steve Karting
    Jul 18, 2018
    151
    Stephen G
    Ernie and FBB ... you guys are entertaining! Like to get things done!
    I'm getting pretty good at this whole darned process, as it calls for the belt to go on and off a few times in order to get good alignment with the camshaft dowel holes! The thing I have learned during the past few hours more than anything else is that the process is iterative! You can line the whole thing up perfectly on any given attempt, but after you rotate the engine, there will be change! Also, when you finally reach the last part of the process when you are carefully moving the dowels while the cogs remain in place, you are not guaranteed to find a hole, so the game starts to feel a little like Snakes and Ladders, it is now time to go back a few rungs.
    FBB ..... One thing I am yet to digest perfectly is the 1st page you had on the Degreeing Cams post from May 2007, where you calculated the centerlines of the cams using the "magical schematic" from the WSM. But I'll get it!
  3. 348steve
    348steve Karting
    Jul 18, 2018
    151
    Stephen G
    OK, finally got it, and of course the math was correct. (Lead+180+Lag)/2 - Lead = the Intake center line. The reason why I could not understand your original post was because the font was not recognized by my browser on this "older technology forum" and the "minus" sign showed up as a square .... :)
    ernie likes this.
  4. 348steve
    348steve Karting
    Jul 18, 2018
    151
    Stephen G
    ernie, copterjon and steved033 like this.
  5. 348steve
    348steve Karting
    Jul 18, 2018
    151
    Stephen G
    OK, here is what should be the final post on this thread:
    The shims are all in and all lash is perfectly in spec. That took a long time and three separate orders of shims. Pain in the butt.
    - The belt/cams went on in an iterative process; you line it all up, install the belt on locked cams and free cogs, set the pins, release the cams, rotate the engine and tension the belt. The previously perfectly lined up marks will move! Then you individually adjust each cam till you have the factory marks lined up. Holding cams, moving pins, etc....
    - Then you get your trusty dial gauge and spend a bit of fiddly time getting it setup so that you can actually measure to see if your cams are in spec, or in other words if the factory marks are worth their salt.
    - The marks were 110% perfect, using the lobe centerline method. Right down to the 1/2 degree.
    Thanks for the help!
    ernie and steved033 like this.
  6. fatbillybob
    fatbillybob Two Time F1 World Champ Consultant Owner
    Aug 10, 2002
    29,472
    socal
    Nope! I got last post...Good Job! The weather is great go driving.
    348steve likes this.
  7. Rupp3r
    Rupp3r Karting
    Aug 26, 2016
    184
    France
    Thanks for your experience 348steve will surely help me in this process also and good job!
  8. ernie
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    Excellent!
    Thanks for the update!
    And that is another F119 with cam marks that are spot on. ;) For whatever reason the factory made the F119 cams dead nuts on the marks. Thank you to whoever was in charge of 348 cams at the Ferrari factory.
  9. emac
    emac Formula Junior Silver Subscribed
    Sep 14, 2014
    851
    upstate SC
    ernest
    Good read, thank you for posting the follow up stuff. I am planning a major(355) this winter, and this really helps take some of the mystery out of cam timing.
  10. Ferrarium
    Ferrarium F1 Veteran Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Not familiar with terms, bear with me, regarding "belt over all pullys and 3/4 cogs".. are the cam gears numbered and this refers to the cam pulley numbers, like the 2 pulley numbers over 1-4 bank or similar? Thanks for the clarification, its not your description its my understanding that's lacking. :)
  11. steved033
    steved033 F1 World Champ Owner Silver Subscribed
    Apr 12, 2017
    10,565
    Atlanta, GA
    Steve D.
    that's 3 of the 4 cogs...not three-quarters. see 3 of the 4 cam pulleys (cogs) in place in post 29.
    put the last cog on the belt and snap it into place. do all with cog pins out so everything moves.
    when I do mine again, I've degreed the cams once, and the marks align perfectly. i'll matchbook the cams on their marks, and just put it back together. no need to check again. (IMO).
    sjd
    uber2 likes this.
  12. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Got it, yes I know it was a count but I call them cam gears or pullies not cogs so I was not clear. Thought I was missing something. It was a definition thing for me is all.
    Sounds like putting the belt on the cog then sliding it on as opposed to wrestling with the belt over the pullies is a good idea and obvious when you hear it so thanks all.
    I get removing the dowel locating pins from the cam to cog/pully for setting timing.
    Thanks!
    Sent using FerrariChat.com mobile app
