Verification: 355 Wheels on a 348 | FerrariChat
Discussion in '348/355' started by Action_Item, Dec 5, 2003.
  1. Action_Item
    Action_Item Rookie
    Oct 4, 2003
    30
    Chicago, IL USA
    Todd Short
    I too have wondered and discussed with others the possibility of 355 wheels on a 348. Although i do not have mine on yet, here is a pic of a 1990 348TS with the 355 wheels so everyone can see for themselves that it does work. Using 348 lug bolts to put them on is another story...
  3. BrentC
    BrentC Formula Junior
    Aug 13, 2003
    278
    If you need different lug bolts, let me know. I stock Hill Engineering's upgraded lug bolts and have both 348 and 355 parts in stock. If you need spacers or custom lengths, I can help you with that, too, but not from stock; they would have to be ordered, but lead time is like 3-4 days.
    Also, I am in Michigan, so not far from you. PM me or e-mail at bcardani@dexmllc.com if I can be of help.
    Best regards,
    Brent Cardani
  4. worth it
    worth it Formula Junior
    Oct 31, 2002
    299
    North Carolina
    David C.
    #3 worth it, Dec 9, 2003
  5. Cavallino Motors
    Cavallino Motors F1 World Champ
    May 31, 2001
    14,143
    Florida or Argentina
    Martin W.
    looks like your car sits now higher than normal. Is that just my perception?
  6. worth it
    Oct 31, 2002
    299
    North Carolina
    David C.
    I did not measure height differeneces from before and after. However, the photo was taken on a driveway with an incline. The rear is on the flat and the front is already on the higher part of the driveway.
    Ride clearance around town is as bad as it was before the wheel change but the performance value has improved.
  8. axtman
    axtman Rookie
    Dec 10, 2003
    34
    Lincoln,CA
    Douglas Axt
  9. worth it
    Oct 31, 2002
    299
    North Carolina
    David C.
    What you are saying is for another $3000 I can have drilled rotors, pads and painted calipers.
    I know what the cosmetics differences would be but what / how much performance difference would be gained ??
