News
Which Suspension Mode is Sport?
Discussion in '348/355' started by sgtpeper, Jun 22, 2020.
  1. sgtpeper
    sgtpeper Formula Junior
    May 4, 2004
    344
    Denver
    Jeff
    I'm making a new thread for this. Everyone says that when the light is on on the dash, that the car is in sport mode. However, I found this note from the dealer my car was purchased at saying something to the contrary. So which is it??
    See item 7 on the attached image.
    Thanks,
  3. Qavion
    Qavion F1 Veteran
    5,178
    Ian Riddell
    #2 Qavion, Jun 22, 2020
    A confusing issue which has been talked about several times on the forum. I think it's safe to say that you have a light which says SPORT and a switch which says SPORT (and the switch is aft/down), then sport is what is selected. I have a gated Australian F355 which doesn't have a switch or light labelled "SPORT", but a different symbol (a shock absorber). The light illuminated indicates that I'm in soft suspension mode (which is considered abnormal in some circles). If you have an F1 car, SPORT affects the gearchange and the suspension.
    I stand to be corrected :p USA cars are very confusing. I'll try and find the message threads relating to this.
  4. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    12,767
    Mesa, Arizona
    Robb Williamson
    I believe 95 is always in sport without tripping the switch and without the light in the dash.
    rest of years, you have to click the switch to be in sport mode and then the light will go on in the dash.
    :D
    Robb
    308 GTB and MAD828 like this.
  5. Qavion
    Qavion F1 Veteran
    5,178
    Ian Riddell
    Or as in my case (a '98), it doesn't. Sport mode is no light. Hence my comment about "SPORT" labelled switches.
  6. To remove this ad click here.
  7. Gizzi
    Gizzi F1 Rookie
    Silver Subscribed Owner
    Dec 3, 2011
    4,528
    Brisbane, Australia
    Gezim
    Interesting! I thought it was the other way around also, but there you go. I’d better check to make sure the actuators are actually working
  8. Qavion
    Qavion F1 Veteran
    5,178
    Ian Riddell
    If in doubt, consult your Owner's Handbook. That's what mine says... light illuminates for comfort. Do you have a shock absorber symbol or "SPORT"?
  9. sgtpeper
    May 4, 2004
    344
    Denver
    Jeff
    Interesting. I didn't realize there were 2 options - mine is the shock absorber. Why would there be 2 different versions? My car is gated.
    So with a shock absorber button, when the light is on, the car is in comfort?
    Ferrarium likes this.
  10. Ferrarium
    Ferrarium F1 Rookie
    2,996
    Central NJ
    Eric
    Because its not German, its Italian. Wonderful isn't it. I think so. :)
    ThatFlyGuy likes this.
  11. To remove this ad click here.
  12. 97 Spider
    97 Spider Formula 3
    2,209
    Texas
    Brian
    It was a change in the production run. Early cars have a shock symbol and when it is lit up you are in SPORT, later cars 98+ish have the SPORT symbol and when it is lit up you are in comfort. You have to love those Italians.
  13. zstyle
    zstyle Formula Junior
    394
    Fountain Hills
    Jon
    There are three different sports switches for the 355 series with the '95 as the odd ball having the Sport suspension always on unless manually turned off.
    Robb and 308 GTB like this.
  14. sgtpeper
    May 4, 2004
    344
    Denver
    Jeff
    I think that's the same on my '97
  15. emac
    emac Formula Junior
    780
    upstate SC
    ernest
    Pretty sure my 96 spider gated is in comfort mode when the light is on. Default is sport, light off.
  16. Robb
    Robb Moderator
    Feb 28, 2004
    12,767
    Mesa, Arizona
    Robb Williamson
    Well I know the 95 mode. And our 97 is opposite...
    time for the rest of you owners to read the manual...
    Robb
  17. 97 Spider
    97 Spider Formula 3
    2,209
    Texas
    Brian
    Qavion likes this.
  18. 308 GTB
    308 GTB F1 World Champ
    10,061
    New Jersey
    Barry Wolinsky
    Robb likes this.
  19. 308 GTB
    10,061
    New Jersey
    Barry Wolinsky
  20. 308 GTB
    10,061
    New Jersey
    Barry Wolinsky
  21. bjwhite
    bjwhite F1 Rookie
    Mar 17, 2006
    4,037
    Seattle, WA
    Brian White
    What about my 348?
    Oh yeah, it's ALWAYS in sport mode, no button or light needed. ;)
    308 GTB likes this.
  22. Gizzi
    Gizzi F1 Rookie
    Dec 3, 2011
    4,528
    Brisbane, Australia
    Gezim
    Mine has a shock absorber symbol. I’ve just read the rest of the comments here...wow! It’s worth a giggle, these bloody Italian electrics!
  23. eyboro
    eyboro Formula Junior
    981
    Chicago
    Eitan
    You're wrong, it's the other way around 95-97 lit-up= comfort 98-99 lit-up=sport
  24. Qavion
    Qavion F1 Veteran
    5,178
    Ian Riddell
    Brian corrected himself later. Also, I have a '98 which disagrees with your statement. I have a shock absorber symbol on my '98.
    As I said and as the manual pages above show...
  25. 97 Spider
    97 Spider Formula 3
    2,209
    Texas
    Brian
    Yeah, that’s what I meant then typed it perfectly backwards. It was too late to edit when I realized but I then made post #16 with the manual screenshots.
  26. 97 Spider
    97 Spider Formula 3
    2,209
    Texas
    Brian
    So the 95 manual mirrors exactly what the 96, 97, and at least part of the 98 say. Seems the only outliers are the later production 98 and 99 that have the “sport” light.
