550 Barchetta facts | FerrariChat
550 Barchetta facts
Discussion in '456/550/575' started by marcos, Jan 2, 2004.
  1. marcos
    marcos Formula 3
    Dec 30, 2003
    1,430
    Zuid-Holland - Nethe
    Marc den D.
    #1 marcos, Jan 2, 2004
    Second try…
    It seems nobody knows an answer to my questions…? So I’m going to try it again.
    Can anybody tell me something about the 550 Barchetta? What I’m looking for is the Specific Power (…HP/Litre), what type of clutch it has, the gear ratio and the type off electric system it’s got.
    I was also wandering if the suspension is the same as the Maranello?
    If you have an answer, let me know.
    Thanks,
    Marc.
  2. ze_shark
    ze_shark Formula 3
    Jul 13, 2003
    1,274
    Switzerland (NW)
    In my humble knowledge, everything except
    - the wheels (modular wheels were standard)
    - the seats (the sport seats were standard)
    - the body (convertible of course)
    is the same as a 550. No engine or gearbox change I am aware of, but I am no specialist on the matter.
  3. marcos
    marcos Formula 3
    Dec 30, 2003
    1,430
    Marc den D.
    I also thought so, but the 550 Barchetta has a top off 300 km/h (186 mph) and the 550 Maranello a top off 320 km/h (199 mph).
    There’s got to something different?
  4. cavallino
    cavallino Formula Junior
    Aug 21, 2003
    449
    Switzerland
    Alain
  5. Doody
    Doody F1 Veteran
    Nov 16, 2001
    6,099
    MA USA
    Mr. Doody
    what's the confusion?
    that's 186mph for the barchetta (whose canvas, snap-on top is NOT to be used over 60mph or something like that - so by definition that's 186 "open"); and 199mph for the 550 maranello, available in coupe form only.
    makes total sense vis-a-vis aerodynamics.
    doody.
  6. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,237
    Austin, TX
    Randy
    Sort-of. The only difference is there's no roof top. There is a hardtop, but pretty much, it is always open air. There's no soft top, nor way to change it over easily, unless you purchased the hard top and put that on there.
  7. jmillard308
    jmillard308 F1 Veteran
    May 29, 2003
    6,579
    Perth West Oz
    John Millard
  8. Willis360
    Willis360 F1 Rookie
    Aug 4, 2001
    3,928
    Redmond, WA
    Willis H
    I think what Schatten meant was that an aftermarket hardtop (very ungainly one at that) can be purchased for the Barchetta.
    The emergency softtop, for the times you get caught in the rain, is good for 70MPH according to the factory.
    Outside of some structural reinforcement, the barchetta is pretty much the same as a standard 550.
    There is a company in Milan that will convert your Barchetta into a "Spyder" by adding a fully functional convertible top.
  9. F1racer
    F1racer F1 Rookie
    Oct 5, 2003
    4,749
    Laval
    Jean
    -It has 485 bhp like in the 550 Maranello....
    -Only 448 Barchetta ever produced.
    -Top speed = 186 mph compared to 199 mph in the 550
    -The interior is pretty much the same.
    -When the top is down you could only reach a topspeed of 68 mph.
  10. amenasce
    33,108
    Joe Mansion
    U meant when the top is on.
    Without the top ( or emergency top ) it can go top speed.
    Its a barchetta , so it was meant to be used without any top. The top that comes with the car is for emergency use only ...as its the case with every barchetta bodied cars.
    Later a german company offered a Hard top for the barchetta..
  11. zjpj
    zjpj F1 Veteran
    Nov 4, 2003
    6,124
    Usually they stiffen the chasis, so, convertibles are usually heavier than their hard top counterparts. But in this case, both models weigh the same. So, weight doesn't explain the top speed difference.
  12. Doody
    Doody F1 Veteran
    Nov 16, 2001
    6,099
    MA USA
    Mr. Doody
    i'll bet dollars for doughnuts that aerodynamics explains the top speed difference. coupe -vs- no-top has to have a wildly substantial effect on the aerodynamics.
    doody.
  13. rodsky
    rodsky Formula 3
    Mar 24, 2003
    1,601
    Los Angeles
    Absolutely agree - its completely aerodynamics that will account for the difference.
  14. AnotherDunneDeal
    AnotherDunneDeal F1 Veteran
    Jun 2, 2003
    6,109
    N.Richland Hills, Tx
    James Dunne
    One difference is that the windshield rakes just slightly more and is about 1" shorter than the 550. If you will look at the framework around the windshield you will notice that it only goes up about 1/2 the way to the top of the windshield on the outside. A tall person will notice this as the field of vision is slightly decreased.
  15. Ekasilicon
    Ekasilicon Formula Junior
    Jan 21, 2003
    507
    My vote makes 3 of us. I would be floored if it was not aerodynamics/drag that kept its top speed down.
  16. Casey_A
    Casey_A Rookie
    Dec 31, 2003
    27
    Texas
    You will always see top speeds listed as such:
    Gear limited
    Electronically limited or
    Drag limited
    I believe the massive amount of drag caused by an open top would account for that loss of 12 or so mph.
    Infact I am certain of it.
  17. marcos
    marcos Formula 3
    Dec 30, 2003
    1,430
    Marc den D.
    Okee, so the combination of aerodynamics/drag is the main cause…
    …in fact I could have thought about it myself. I just thought the top speed difference was too big, so there had to be another reason.
    I think they did stiffen the chassis, but the weight is the same, because they “cut-off” the roof. Barchetta and Maranello both weight 1690 kg.
    I only have one question left; does the 550 have a single plate clutch or twin-plate clutch?
    By the way, nice site you got there Alain.
  18. TimN88
    TimN88 F1 Veteran
    Jun 12, 2001
    5,045
    Northeast
    Tim
  19. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,461
    Osprey, Florida
    Ali E. Haas
  20. davequick
    davequick Formula Junior
    May 27, 2003
    307
    Bellevue, WA
    Dave Quick
  21. F1racer
    F1racer F1 Rookie
    Oct 5, 2003
    4,749
    Laval
    Jean
    LOL yeah ..wrong word
  22. F1racer
    F1racer F1 Rookie
    Oct 5, 2003
    4,749
    Laval
    Jean
    When the top is on you could only reach a topspeed of 68 mph.
  23. labcars
    labcars Formula 3
    1,589
    Phila. + Scottsdale
    Willis - I thought the conversion company converted 550 coupes into spyders? Do you recall their website?
    Just to be clear----I AIN'T CHOPPIN' THE TOP OFF MY BEAST!!
  24. Willis360
    Willis360 F1 Rookie
    Aug 4, 2001
    3,928
    Redmond, WA
    Willis H
  25. Willis360
    Willis360 F1 Rookie
    Aug 4, 2001
    3,928
    Redmond, WA
    Willis H
